Placement of Z-Wave AC Motor Controls
Hello,
We want to automate some existing motorized AC shades in our house. Most of our house is controlled via Lutron Radio RA2 but these shades pre-date the Radio RA2 install and getting these shades RA2 compatible is pretty much a dead end and all I really need to do is put the shades on a timer for the most part - manual control is not that important and intermediate stopping points are never used (open or closed only).
With that intro, we have 3 “dumb” AC shades with internal control limits. There are 3 up-stop-down type switches ganged together on the wall. Are there any z-wave AC motor controls that I could mount inside of our existing 3-gang remodel box (fit 3 of them, that is)? We don’t need wall switches as well so we could cover the controls with a blank face plate. (We’ll do all the control from the iPad or some tabletop device).
Just to head off other questions - the reason to mount motor controls in this place is that the shades are mounted inside a custom built enclosure that would be very difficult to remove/refit (I didn’t build this, just bought the house).
Thoughts? The ABMHZ and AC1-ZW both look a little large and that Aeon product sounds a little scary (in terms of relay isolation on the up/down motor).
The Fibaro blind control modules should work for you. They control 3 wire AC motors and are quite small.
Sent from my Nexus 7 using Tapatalk 4
contact us at info@zwavemotors.com
We specialize in shading motor controls and have all kinds of AC controllers that fit in electrical boxes, dry contact interfaces, sensors
I remember controlling standard AC shade motors with radioRA but would have to look at the specifics.
Do you also have Lutron shades in the house?
Do you want to use Z-Wave only to control 3 motors via timer or do you have more in your zwave network?
Those Fibaro controllers look perfect. But, is there a US version? Or can I run EU z-wave without a problem. This will be the only thing controlled via zwave so compatibility with the rest of the system isn’t a problem.
we have 120V AC motor controllers in US freq. Shown here with optional momentary up/dwon center off switch and deep remodel singel gang box if you want to fit everybody in the same box
