Hello !
I thought I saw some plugin in app store to control pioneer receivers…but I can not see anymore…
this receiver has lan port and a lot of resources… is possible to control from vera ?
in this link you can see the features:
thanks for help…
Hello !
thanks for help…
I don’t think it was ever in the store.
Code page is here though:
http://code.mios.com/trac/mios_pioneer-receiver
Along with the forum thread which you’d have found by searching ![]()
http://forum.micasaverde.com/index.php/topic,9039.0.html
The link you posted to Best buy is a newer 4K model though.
Per this post:
http://forum.micasaverde.com/index.php/topic,9039.msg120299.html#msg120299
Seems it can work with some modifications.
I will install this files and try and let you know…
I dont know like make changes to files…
I can need help…
thanks !!!
I was able to get my Pioneer Receiver VSX-1021 working somewhat. So far I am able to create a scene to turn it OFF but when I make a scene to turn it ON nothing happens. I stopped there since what’s the point if I can’t turn it ON.
Any suggestions? I running it on UI5 v1.5.622
I think there is a power saving function you need to turn off in the receiver IIRC.
Thanks, that was the issue. Under network setting there is a network standby feature. I disabled it (OFF) and now I can turn the receiver on. Thanks again.
