Just installed the ping sensor in UI4 , create a new device.
Pinging will work ( sensor will be tripped , or not tripped )
But after creating a scene , when sensor is tripper ( means ip is active ) . Set power state ( plugin module) to on.
But there is no response on the scene
The ping sensor will work in UI2 & UI4. However it has issues.
#1. It cannot be bypassed, when manually toggling from Arm to Bypass it appears to be in Bypass mode but the sensor will continue to ping. Having a scene toggle Arm & Bypass does not work.
#2. The code of the plugin has errors and will cause more problems with UI4 than UI2.
#3. Due to the code errors of the plugin it will use more Vera memory logging those errors.
JOD.
