Pin Codes Stop Working on Restricted Pins Only
I am using a new Vera Lite with mios U15 and a Schlage BE369 deadbolt lock. I use Pin Codes with the lock. I have Restrictions on the Pin Codes, such as a Daily Restriction that allows access 24/7, but expires in 2020, or one that allows 24/7 access, but expires in a few days. For those Pin Codes with Restrictions, the pin codes stop working after a day or so and the lock flashes a red light. >:( Those pin codes with no restrictions, have thus far (1st week with system) worked fine. :o
What are the possible problems, the lock, Vera Lite, MIOS? Not sure how to troubleshoot the system.
Thanks for any help.
Rick
I’m having similar issues. The PIN code works fine if I don’t set a restriction. Once I add a restriction, it doesn’t work within a appropriate time. Were you able to figure this out?
I am having the same issue using a Kwikset Lock. When I add restrictions to the pin codes they do not work. The unrestricted codes work fine.
