Pin code on alarm System - hardware?
I set up an alarm system with z wave devices, like motion sensor, door and windows sensor and a siren.
I would like have an hardware in front of my door where I put a pin code and the alarm is activate or deactivated,
Is there some hardware like this? I know that I can you schlange or kwiset, but I don’t have it.
Thank you
Nobody has any information about this possible hardware?
Thank you
Up :slight_smile:
There is no hardware that I know of like this. If you really want to have a good security system, I would invest some money into an alarm panel and get a few sensors. There are many alarm panels that work with vera and you can use the sensors of the alarm panel with vera for scenes and so forth.
  • Garrett
Still no news on it?
I saw that poly form has the key pad, but is not yet in the market
So you can at least disarm by using any of the Zwave locks and a specific PIN, but arming is a different matter, without a real kludge!
Not sure it would work, but you could also maybe use these:
http://www.amazon.com/Wayne-Dalton-WDHA-12R-HomeSettings-Wireless-Gateway/dp/tags-on-product/B001HL3CS8
http://www.amazon.com/Wayne-Dalton-KEP-IV-Wireless-Keyless-Entry/dp/B0028N65O2/ref=pd_sxp_grid_pt_0_1
Or maybe arm and disarm from a keyfob using with the above gateway and this:
The Poly-Pad is perfect for arming and desarming your Alarm system.
Check out domadoo.fr or get back to me direct through mail@poly-control.dk
