There are some attempts to this on the forum, but I didn’t find any solution.
I want to change the source of my Philips TV from HDMI1 to HDMI2 using JSON in luup code.
How can I do this?
How can I do this?
http://jointspace.sourceforge.net/projectdata/documentation/jasonApi/1/doc/API-Method-sources-current-POST.html
http://jointspace.sourceforge.net/projectdata/documentation/jasonApi/1/doc/API-Method-audio-volume-POST.html
http://jointspace.sourceforge.net/projectdata/documentation/jasonApi/1/doc/API-Method-input-key-POST.html
How can i do this with lua code?
http://ip-address:1925/1/sources/current
POST json
“id”: “hdmi2”
[quote=“dawiinci, post:2, topic:180061”]How can i do this with lua code?
POST json
“id”: “hdmi2”
}[/quote]
function SendInputCommand(ipAddress, inputName)
local http = require("socket.http")
local lRequest = [[{"id":"]]..inputName..[["}]]
local lURL = [[http://]]..ipAddress..":1925/1/sources/current]]
local contents,response=http.request(lURL, lRequest)
SendInputCommand("192.168.1.111","hdmi2")
