Hello,
today received Vera Plus. My first time with Vera. Firmware 1.73232. Hue APP 1 V1.28 installed and connected with hue brigde, device status link is green. But device cannot switched on, command failed is shown.
What to do?
Thanks.
Michael
Hello,
What to do?
Thanks.
Michael
I’m in the same boat any work on this
Try installing Philips Hue 2 plugin from the Vera page. That is version 1.75 and will probably address the issue.
as an alternative, you can also try the ALTHue plugin in case it works better for you. http://forum.micasaverde.com/index.php?topic=77266.0
I second the AltHue plugin. Worked perfectly on the first try.
