Philio PSR04 Smart Color Button pairing Vera Plus 1.7.1754
I have a Philio PSR04 Smart Color Button and try to get it to work with the Vera Plus.
I get it to pair but it comes up as a GenericIO.
Switching on and off does not show up in the UI. I even added a scen to control a lamp with the PSR04 but nothing happens.
Are there any parameters that need to be adjusted? I changed parameter 1 to 1 but nothing helped.
Is there anyone that have the PSR04 up and running with Vera?
Helge
Did you associate a device unto the PSR04?
You need to associate PSR04 with a device - dimmer , thermostat or roller shutter. The association group of PSR04 is group after setting the configuration you need to wake the device up. To wake device up, put the arrow downward and press three times.
How can i associate with other device like dimmer?
What is the option on device?
Before you associate, make sure that it is on automatic configure.
Then go to device options, on associations
Group 2: and associate the node ID of the device (dimmer) and save it.
Once save, wake the PSR04 up by tapping it once. (make sure PSR04 is parallel to the wall and its pointer is pointing downwards.)
[quote=“lrbc, post:3, topic:191474”]Hi,
Thanks[/quote]
