I’ve been making some organizational changes to my Vera and somehow I’ve ended up with a Phantom Room in the Device Display that does not appear in the Setup/Rooms List.
Anyone know a way to remove it?
Try the following:
Enter http://ip_address:3480/data_request?id=user_data&output_format=xml in a browser.
Search for and find the ID for the phantom room.
3 Enter http://ip_address:3480/data_request?id=room&action=delete&room=ID, where ID is replaced with the ID for the phantom room
Note: replace ip_address in 1 and 3 above with the unique ip address of your Vera.
[quote=“BrianLBeaton, post:2, topic:187771”]Try the following:
Note: replace ip_address in 1 and 3 above with the unique ip address of your Vera.[/quote]
Thanks, I’ll give that a try
[Update]
That appears to have got it, thanks
