I just added a Schlage lock a couple of days ago after my lighting had stabilized. Today I added a Panasonic BL-C111A and Vera found it with no problem. I can get to the camera locally and remotely with one exception. I don’t seems to be able to use the Pan/Till/Zoom functions thru Vera although everything works thru the Panasonic software. Has anyone encountered this problem?
This should work. We do a pan/tilt of the Panasonic cameras in our test plan. I suggest enabling Verbose logging, trying to move the camera, and then submitting a trouble ticket.
