Override Mios
In the settings is a field-set called “override mios settings”
I put there my external hostname and port.
This results in connects within the local network to take forver or never happen.
Also the cloud-icon on the app do show right from the start.
Is there a way to use a external setting vor connect, but still use the vera ip if inside the network ?
Probably just a setting wrong on my side.
Oh one more suggestion for the new version.
The settings show “keep iphone on”
I assume thes for the sleep mode … Since homewave do run on all ios devices this may should say “device” instead of “iPhone” :slight_smile:
Odd. When setting an external IP address and port for your Vera, connecting locally should still work. What exactly are your settings?
If your Vera is directly accessible from the Internet, you should specify its host & port in the “Host / port” field, and switch on “Direct to vera”. Leave “Ignore MiOS settings” Off
oh okay i try basically all settings …
the url field uses the full url like "http://blahblah:port/
Direct to Vera and Ignore Mios was on
turned Ignore Mios off now, seemd to work.
maybe was some sort of messup in the network settings because of the VPN … not sure, works just fine now
I am having a similar issue,
Vera IP Address and URL are set
Direct to Vera is on
Ignore MiOS IP is off
I did a quick packet capture and Homewave is requesting
http://192.168.0.100/(null)/(null)/(null)/data_request?output_format=json&id=lu_status
The Vera responds to HomeWave with a 404
HomeWave and the Vera are on different subnets
I probably have something configured wrong, my guess is that /(null)/(null)/(null)/ are pulled from some configuration field that is setup wrong.
Thanks in advance for any advice.
I’ll have a look
This looks like you are trying to do a remote access on a LAN.
I hope that when you do a real REMOTE access that you are using HTTPS … othwerise you can potentially exposing the password for a user.
Thanks for your help intveltr!
Hi Richard,
No internet access to for the Vera, inbound and outbound connections are blocked at the firewall.
@frss87
My comment was meant for @intveltr
[quote=“frss87, post:4, topic:175598”]I am having a similar issue,
Ignore MiOS IP is off[/quote]
The Override URL is meant for external access:
  • It is interpreted as an alternative URL for the MIOS server (when “Direct to Vera” is off)
  • Used as a direct connection to Vera from outside the LAN (when “Direct to Vera” is on)
If HomeWave detects that it is on the same LAN as Vera, it will attempt the configured IP address first. If that fails, it will try the Override URL if configured.
There’s a minor bug in the connection sequence; with a Override URL configured and Direct to Vera turned on, HomeWave will (correctly) first attempt to connect to Vera at the specified address, but will then (incorrectly) attempt to fall back to MiOS, interpreting the Override URL as the MiOS address. That’s why you saw the extra null parameters; these are normally your MiOS credentials and Vera unit ID. (Bug is fixed in the next version)
From your description I gather that you are trying to connect to your Vera on your home LAN, without using MiOS and on a different subnet. To do this:
  • Clear the Override URL setting
  • Direct to Vera = OFF
  • Ignore MiOS IP = ON (this tells HomeWave to disregard the IP address that is reported by MiOS)
If you specify the right IP address in the IP field, HomeWave should be able to connect, provided that there is a valid route between your 2 subnets.
[quote=“RichardTSchaefer, post:6, topic:175598”]
I hope that when you do a real REMOTE access that you are using HTTPS … othwerise you can potentially exposing the password for a user.[/quote]
All remote access to MiOS and the discovery service is over https :slight_smile: If someone uses the Override URL, they have to specify the https part themselves.
