outdoor wifi direct 120V connection cameras?
Does anyone know of any outdoor wi-fi cameras that are direct-connect to 120V power, i.e. that have the transformer internally and do not require a power brick.
bump
I have never seen one. I think it is very unlikely that you will find one. It is too difficult for a camera manufacturer to have to pass all of the required safety standards for each market it wants to sell in. That is the reason a lot of devices use external power adapters. Any possibility you could mount a 24VAC door bell transformer in a junction box to power it?
-bob
You can try Poe switch if ur camera is compatible its nice
True, but alternatively there’s probably a bunch of people mounting transformers in unsafe ways, inside walls, crawlspaces etc. Poe is not an option, I don’t want to run wires to it, I simply wanted to tap off an existing exterior flood light fixture. Will consider the bell box suggestion.
