I have an outdoor water slide and waterfall that are turned on by two separate toggle switches housed in a steel box.
My zwave network is controlled by a micasa verde light
I would like to replace these toggle switches with a zwave enabled switch that would allow manual operation of each load and also automate turning off the waterslide/fall when no one is using it.
I would like to have opinions on which simple zwave switch is reliable and would withstand being outdoors, even if it is housed in a box.
I have also seen a Levitron switch with two independent switches on one wall plate. Will this power two separate loads or just two scenes
You could put a Fibaro FGS221 (2 x 1.5kW) switch module in the box and control it with the existing toggle switches and Z-Wave. I use these modules all over my house and I have found them reliable. They are designed for indoor use but, if the box is weatherproof, that may not be a problem.
What country are you in? Your answer is based on the location of where you are. The solution RexBeckett provided is not for US as the fibaro zwave device listed is for Europe. If you are in the use, you can use something like the Aeon microswitches (similar to the fibaro, but you’ll need two to control via two switches.
I live in the united states.
I had thought of using the modules as described but I was told that remote control of this switch via zwave would not automatically toggle the switch, meaning that if the toggle was on the "on position and then I turned it “off” by computer, then the toggle would remain in the up “on” position. Then to turn back on you would have to flip it to the opposite position (opposite whatever toggle position the switch is in). Am I thinking about this correctly?
THis is for a rental house and I think that setup might confuse people if so.
If the enclosure has a weatherproof door you could probably use normal switches. If the switches are open to the elements then weatherproof (IP67) momentary-contact switches controlling a Z-Wave module would be a more robust solution.
