Does anyone know of any open/close sensors for outdoor use? I would like to place a couple on my fence gates so I know if they were left open before I let the dog out.
You might be better off using a water proof contact sensor and tie it into a door/window sensor that allows for use of an external sensor. You can put this in a plastic enclosure.
- Garrett
I have the sensor below hooked up to monitor my garage for the last couple of years. It has survived single digits, getting wet and muddy, being frozen, and reaching temperatures of 100-110. The thing is built like a tank! (I have yet to hit it with my snow blower, but stay tuned. I sure I will eventually!) I didn’t want to drill out my concrete so I used “Liquid Nails” on both the concrete and the aluminum for the garage door. Not had a problem yet. This is just the sensor, you will need a device that speaks your protocol of choice to tie it in to your HA system.
http://www.smarthome.com/7455B/SECO-LARM-SM-226L-3-Magnetic-Garage-Door-Contact-Switch/p.aspx
[quote=“garrettwp, post:2, topic:175936”]You might be better off using a water proof contact sensor and tie it into a door/window sensor that allows for use of an external sensor. You can put this in a plastic enclosure.
- Garrett[/quote]
Any suggestions on door/window sensors that allow for external?
I did find this one: http://www.amazon.com/camera-photo/dp/B006TFGW98 I’m not sure if that’s what you were referring to.
fibaro door sensor has this option and the everspring u mention also
I’m using wireless alarm sensors for my gates, with my Vista 20P alarm system. They are enclosed in a waterproof box, and use a strong magnet on the gate itself. So far they have worked great out in the weather, if you don’t have Vera connected into your security system this solution won’t help.
Wireless Sensor
http://www.security.honeywell.com/hsc/products/wireless/do/21234.html
Waterproof Box
http://www.ebay.com/itm/150804735037?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
[quote=“fba, post:3, topic:175936”]I have the sensor below hooked up to monitor my garage for the last couple of years. It has survived single digits, getting wet and muddy, being frozen, and reaching temperatures of 100-110. The thing is built like a tank! (I have yet to hit it with my snow blower, but stay tuned. I sure I will eventually!) I didn’t want to drill out my concrete so I used “Liquid Nails” on both the concrete and the aluminum for the garage door. Not had a problem yet. This is just the sensor, you will need a device that speaks your protocol of choice to tie it in to your HA system.
I use the same sensor tied into a MIMOLite for checking if my garage door is open. Was initially planing on mounting it to the floor like it sounds you did, but instead chose to mount it at the top of my garage door – less cable to run and less likely for me or the wife to mess it up.
They are great, and pretty forgiving of how much of a gap you can have for it to register as closed.
iuse a fibaro door sensor … with a 2cm long magnet strip (not the one comes with it) … so the gate can move about 2 cm without beeing triggered “open”
works like a charm, the sensor is taped under the steel frame next to the stabilizer rolls on top. so its protected from the rain water.
i have about 1000 Ants live inside the sensor on a regulary basis (they come trough the Air holes for cables and sensor), but it works fine still ![]()
[quote=“SOlivas, post:7, topic:175936”][quote=“fba, post:3, topic:175936”]I have the sensor below hooked up to monitor my garage for the last couple of years. It has survived single digits, getting wet and muddy, being frozen, and reaching temperatures of 100-110. The thing is built like a tank! (I have yet to hit it with my snow blower, but stay tuned. I sure I will eventually!) I didn’t want to drill out my concrete so I used “Liquid Nails” on both the concrete and the aluminum for the garage door. Not had a problem yet. This is just the sensor, you will need a device that speaks your protocol of choice to tie it in to your HA system.
They are great, and pretty forgiving of how much of a gap you can have for it to register as closed.[/quote]
Would you mind giving more information on how you mounted it on top of your garage door? I bought one, but am having problems figuring out how to mount it. If you have a picture, that would be awesome. ![]()
Sure.
[s]
What I did was use two pieces of velcro to mount it in an empty spot on the back side of the opener. I then ran some wire from the MIMOLite to both the contacts that the switch on the wall that opens the door is wired to, as well as a sensor mounted at the top of my garage door.
Here is a picture of the MIMOLite. Sorry, I don’t have my ladder handy to get up closer to it for a better picture.
The MIMOLite is the small device in lower center area with the wires running from it. I’ve set it up to make it easy to remove from the garage door opener if there are any problems with it.[/s]
Sorry, didn’t read your post thoroughly, going to bed after this.
I’ll post pictures of it tomorrow.
What I did was mount the part of the sensor with the cable coming out of it to the wall of the garage. On the top of my garage door, I have a lip that sticks out a bit. I mounted the bracket to the door using some sheet metal screws and nuts to hold them in place.
I tested the setup first by using duct tape to secure the sensor to the wall, then using a sturdy set of vice grips, secured the other part the the top of the door, once I figured out the best place to mount it was. If I remember correctly, I flipped the magnet around on the mounting bracket, so that it was closer to the sensor.
After opening an closing the door a few times to verify that it worked, I drilled out the holes and secured the bracket in place.
I liked this setup better than mounting it to the floor, since it was out of the way, there was less cable I had to run, and you have to reach up pretty high to mess with the sensor to disable it. Since it is at the top, as soon as the door is open enough for you to come in, the magnet mounted on the bracket is already far from the sensor so it registers an opening.
One thing I also noticed about this sensor, the length of the cable affected the readings, as does temperature.
yup you should not make the contact-cable to long as it drains more battery and makes it work less good.
Here are some pictures of the sensor.
Luckily the MIMOLite is plugged into the same outlet the garage door opener is (the builder was nice enough to put a standard double outlet receptacle above the opener).
[quote=“SOlivas, post:12, topic:175936”]Here are some pictures of the sensor.
Luckily the MIMOLite is plugged into the same outlet the garage door opener is (the builder was nice enough to put a standard double outlet receptacle above the opener).[/quote]
Thanks! This helps a lot!
that looks pretty nice and professional ![]()
Thanks.
I initially left the clamp up (vice grip) to hold it in place for a while longer than I should have to test and for the lack of a ladder at the time (had just moved in and didn’t have one yet). But it worked out fine.
I got the MIMOLite first, and immediately hooked it up before I got this sensor. When I finally got the sensor, I spent some time trying to figure out the best place to mount it. Had though about trying to mount it on the side using existing holes in the track, but the magnet didn’t like that and was too strong – I was afraid I was going to get it caught opening and mess something up.
I wanted someplace where it would be harder to mess with the sensor (something getting in the way, etc) and figured that above the door was the best place. This keeps it from getting abused and from having something placed on, next, above, or between that would likely cause problems. And it keeps the wires out of the way.
Evening all
Am i right think this sensor above used with mimolite is just for a open close signal?
Reason am asking as looking at setting up my automation gates at bottom of garden to be linked with vera but not 100% sure correct way to go about it.
Yes, the sensor is only so you can have a way of knowing if the door/gate/portal/etc is open or closed.
Have you looked at this?
Under the files tab, there is a wiring diagram for a garage door.
You could also look here for inspiration:
http://forum.micasaverde.com/index.php/topic,15713.msg123095.html#msg123095
MIMOlite is something i look arround for quite some time as well.
but for my taste this is seriously overpriced !
is there any competition arround for this application ?
besides the fibaro I/O modules and Raspberry with Zwave ?
[quote=“SOlivas, post:17, topic:175936”]Yes, the sensor is only so you can have a way of knowing if the door/gate/portal/etc is open or closed.
http://forum.micasaverde.com/index.php/topic,15713.msg123095.html#msg123095[/quote]
Thanks for your info. Great help.
One question. I have automation in my gates. How i go about wiring them into this device as they are operated by keykob.
There are other similar type zwave controllers that people have used:
http://store.homeseer.com/store/Remotec-ZFM-80-Z-Wave-15-Amp-Dry-Contact-Fixture-Module-P1455.aspx
