Oregon sensors and Rfxcom LAN
Hello,
I would like to understand the meaning of the 3 channels specs for the THGR122NX.
Does this mean one cannot use more than 3xTHGR122NX with a Rfxcom ?
Did someone ever used more than 3x ?
The channels are normally used when you have a weather station that has a limited display (pretty much all of them), it just allows the you to cycle between your sensors.
As far as the RFXtrx goes, I have quite a few showing up (including the two I own), and it seems to work; can’t imagine the RFX LAN should be any different.
