I bought the meteorological center Oregon Scientific WMR86, its containing 1 wind sensor, 1 temperature sensor, 1 humidity sensor and 1 rain sensor.
When I have put the batteries in the devices, my Vera3 has created the devices automatically, but Vera3 has created twice sensors, it shows me 2 devices temperature, 2 humidity sensors, 2 rain sensors and only 1 wind sensor … well, do not indicate the same reading …
Because there are 2 sensors of each type in vera3 and because they have different value?
Is it normal?
Do you have any close neighbors that could have similar devices? If all devices are regularly updated with new values there is a chance that you have picked up some devices from your neighbors.
Internal being the WMR86 reading from its location and external being the sensor. Rain is reported accumulative total and in last x time. Test by pouring a little water and see what is reported.
korttoma, I do not think is the problem, because I have installed RFXtrx almost a year ago and never have appeared these devices, the devices appeared at the same time I installed the sensors Oregon.
Brientim, The receiver WMR86/display also sends information by rf?
I thought it only received if also emits might be the receiver, because the temperature that may well be read inside …
I am not certain on the specifications but Verify the temperatures and rain against those being displayed. This should either way determine if that match the inside temperature and sensor temperature readings
After several days watching, reading is indeed an outdoor sensor and the other interior reading, I’m surprised that the internal display also transmit their readings, but it looks that way …
