OR operator in condition
Is this not valid syntax for a condition? “trig1 OR trig2”. trig1,trig2 seems to, at least according to the status report. I haven’t tested yet and have learned that you have to test EVERYTHING.
It doesn’t give me a syntax error, but never evaluates true. I could be wrong, but I thought I had used that syntax before 5.5.
Any help appeciated
I am using or in a condition (also on 5.5)
WindowOpen RWindowOpen or LWindowOpen 2013-10-30 19:57:05.361 false
it works fine.
I think the problem is probably somewhere else. Might be worth posting a full status to see where the problem could be
[quote=“shogan50, post:1, topic:178490”]Is this not valid syntax for a condition? “trig1 OR trig2”. trig1,trig2 seems to, at least according to the status report. I haven’t tested yet and have learned that you have to test EVERYTHING.
Any help appeciated[/quote]
Assuming you don’t include the quotation marks (“”) in the condition, trig1 OR trig2 is perfectly valid when trig1 and trig2 are Triggers with binary (true/false) states.
trig1,trig2 is a form of sequence expression. It will be true if trig1 and trig2 have both been true, at some time, in any order and it will remain true if either or both are now false.
As @mikee123 suggests, let us see a Status report and we may be ale to help.
It’s working now. Likely abuser error. :slight_smile:
