Version 1.6 has been contributed by @amg0 to add windspeed variable and is available from the Alt App Store in AltUI.
Am I the only one having an issue when I try to update openWeather that it create all devices in double… instead of just updating ?
Are there two parent devices, or are all these duplicates from a single parent?
I just test it again for you ![]()
And it’s a new parent with 2 new childs with no config!
Are you seeing multiple plugin devices or only duplicate children (or both) ?
Are you running the plugin on Vera or on openLuup ?
The only instance I can think where children would be recreated is if you happen to change the existing children’s Vera device ids (e.g. “OWT” for the temperature child and “OWH” for the humidity one), then new child devices will indeed be created at each restart… the plugin checks for these fixed ids to verify the children already exist or not.
In any case, easiest workaround could be to delete the existing plugin and reinstall the latest version.
I am afraid I cannot do better debugging on this since I no longer run any Vera, having moved all my HA to Domoticz since the beginning of the year after too much frustration with Vera… I just keep an eye on the forum to help as much as I can with the plugins I developed but please keep that limitation in mind.
I’m running it on openLuup!
And like I said before, it create a new parent with 2 new child!
Sorry I missed the exchange you had with Akbooer… Can you please try the workaround I suggested ?[quote=“logread, post:45, topic:191508”]In any case, easiest workaround could be to delete the existing plugin and reinstall the latest version.[/quote]
Looks like uninstalling/reinstall solved the problem!
thanks ![]()
