[quote=“akbooer, post:63, topic:191659”]Happy to add this to the list.
What did you need to change to make it work?[/quote]
I streamlined the code a lot.
Removed the UI_check to save some cpu clock, changed some syntax, in particular: strange html operators in the implementation xml which I think are not working on Openluup/lua but are valid for html.
Removed some functions no longer needed related to downloading a json interpreter for UI5 which was crashing and not needed.
Split out the exec code into a .lua file but this is just personal taste
Can do a github compare as I have the original branch which I had already modified from the mcv appstore version to add some features. This new version will also work on UI7, not on UI5.
Edit: I also moved the icons to be local as opposed to have to go to the web.
I am not sure if you actually want to fix these… To be honest I don’t know which exact part was the culprit. I suspected two of them so I went brute force and removed anything which I thought was superfluous and corrected the “>” and “<” which seem to be html or java operators from what I can tell and it worked…
Can now add ecobee (originally Watou and modified by me to work on OpenLuup),
ALTHue by amg0, the new mcv hue one no longer works.
I also posted another improved Pioneer receiver plugin in the ALT App Store.
