Yes, the logs never indicate a failure. In fact, I don’t want to call it a failure at all - rather an issue with the plugin not polling (what initiates a poll ?). At first, yes - I was concerned with the icon but after reviewing Vera’s logs, my understanding of how things work has changed (the logs are on page 1 of this thread; reply #11).
When openLuup creates the bulbs, the bulb starts out with one variable - ‘BulbModelID’. If a poll were to occur, then other variables would be set and maintained by the plugin.
For example, IconValue, LampValue, Status, Configured, LoadLevelStatus, LoadLevelTarget etc…
[quote=“akbooer, post:19, topic:189406”]Nothing in the openLuup log that indicates anything has failed, then?
Remind me what problem we’re chasing - it’s just the icon is it?
Edit: can you check and compare the attributes for the plugin on both Vera and openLuup ?[/quote]
The polling is done by the function pollHueDevice(), appropriately enough. It is scheduled to run at the POLLING_RATE of 10 seconds, and this is initiated in the Init() function by this code:
local bridgeLink = luup.variable_get(SID.HUE, "BridgeLink", device) or ""
if bridgeLink == "1" then
pollHueDevice()
So if the device variable BridgeLink doesn’t exist, or have the value “1”, then the polling will never start.
That definitely helps. Honestly, I’m almost positive that my bridge is linked - has a ‘1’ and log data has shown me nothing (even have debug set to 1 on the bridge). I can control the lights and the only log data is a change of state that I invoke - never from a poll. So before I start lying, I’ll go home tonight and give it another go. I might just overwrite the ‘1’ with a ‘1’ and see if that invokes the process…
I’ll update with detailed information tonight…
pollHueDevice()
So if the device variable BridgeLink doesn’t exist, or have the value “1”, then the polling will never start.[/quote]
I am confused by the openLuup log (abridged) that you posted…
…although it may just be the way you filtered it (these don’t seem to be in chronological order?)
I see:
[tt]
786 2015-11-03 19:41:48.345 luup.variable_set:7: 7.urn:micasaverde-com:serviceId:PhilipsHue1.Status was: now: Philips Hue Bridge has been discovered! #hooks:0
787 2015-11-03 19:41:48.346 luup.variable_set:7: 7.urn:micasaverde-com:serviceId:PhilipsHue1.BridgeLink was: 1 now: 0#hooks:0
788 2015-11-03 19:41:48.346 luup.task:7: status=1 Philips Hue by MiOS : Philips Hue bridge was detected. Please hit ‘Pair with the Bridge’ button!
[/tt]
and then
[tt]
790 2015-11-03 19:41:48.854 luup.variable_set:7: 7.urn:micasaverde-com:serviceId:PhilipsHue1.Status was: Philips Hue bridge was detected. Please hit ‘Pair with the Bridge’ button! now: Philips Hue Connected! #hooks:0
791 2015-11-03 19:41:48.854 luup.variable_set:7: 7.urn:micasaverde-com:serviceId:PhilipsHue1.BridgeLink was: 0 now: 1#hooks:0
792 2015-11-03 19:41:48.854 luup.task:7: status=1 Philips Hue by MiOS : Philips Hue Connected!
[/tt]
and then
[tt]
32 2015-11-03 19:41:30.998 luup.variable_set:7: 7.urn:micasaverde-com:serviceId:PhilipsHue1.BridgeLink was: EMPTY now: 0 #hooks:0
33 2015-11-03 19:41:31.788 luup_log:7: (Hue2 Plugin)::(findBridge) : Philips Hue Bridge found with IP address: 10.0.4.40
[/tt]
and then
[tt]
37 2015-11-03 19:41:31.794 luup.variable_set:7: 7.urn:micasaverde-com:serviceId:PhilipsHue1.BridgeLink was: 0 now: 0 #hooks:0
[/tt]
So, really, I am totally confused about what the code is thinking it’s doing.
Do you, by any chance, have BOTH the bridged clone devices AND the locally installed Hue plugin devices, on openLuup at the same time? This might confuse the Hue bridge code too. So I would be in good company.
The order result was due to a WinGrep program I quickly installed and used (was rushing out the door that day) as I wanted all the results from the log files.
I am confused by the openLuup log (abridged) that you posted...
...although it may just be the way you filtered it (these don't seem to be in chronological order?)
I do happen to have both local and bridged running on the same unit so I’ll remove the plugin off of Vera when I get home tonight.
[1] Removed plugin from Vera3.
[2] Removed plugin from openLuup.
[3] Restarted openLuup, confirmed the devices were no longer loaded locally or remotely.
[4] Installed plugin on openLuup:
do -- Philips Hue by MiOS
local dev = luup.create_device ('', "PhilipsHue2", "PhilipsHue2", "D_PhilipsHue2.xml")
local sid = "urn:micasaverde-com:serviceId:PhilipsHue1"
[5] Log data, see phue_install_1.txt
[6] Pressing the pair button on the bridge. Then reload.
2015-11-06 20:01:58.570 openLuup.server:: /data_request?id=action&output_format=json&DeviceNum=57&serviceId=urn:micasaverde-com:serviceId:PhilipsHue1&action=BridgeConnect tcp{client}: 0x2937e48
2015-11-06 20:01:58.572 luup.call_action:: 57.urn:micasaverde-com:serviceId:PhilipsHue1.BridgeConnect
2015-11-06 20:01:58.576 openLuup.server:: request completed (62 bytes, 1 chunks, 5 ms) tcp{client}: 0x2937e48
2015-11-06 20:01:58.576 luup_log:57: (Hue2 Plugin)::(bridgeConnect) : Linking with the Bridge device
2015-11-06 20:01:58.639 luup.variable_set:57: 57.urn:micasaverde-com:serviceId:PhilipsHue1.Status was: Philips Hue Connected! now: Please press the link button on the Bridge and hit the Pair button again! #hooks:0
2015-11-06 20:01:58.640 luup.variable_set:57: 57.urn:micasaverde-com:serviceId:PhilipsHue1.BridgeLink was: 1 now: 0 #hooks:0
[9] And the remaining images from the install…
[10] If I attempt to re-enter the ip address for the bridge device I get ? 11/6/2015, 8:30:11 PM Error in PhilipsHue2.setPhilyHueIp(): TypeError: Utils.trim is not a function
[11] And the Java console says: INIT
J_PhilipsHue2.js:43 bridgeLink: 1, status: Philips Hue Connected!
The thing that it making the logs so extensive is that you are testing this on a fully configured system. I see: VeraBridge linking to a remote Vera with Zwave activity, scenes running, the Extensions plugin, System monitor plugin? …
To make it much simpler, could we test on a system with just AltUI and the Hue Bridge? I’m imagining a startup.lua file like this:
I don’t expect that this will change anything (although there is the remotest possibility that several plugins are, somehow, interfering) but it will make things a whole lot easier to understand. Then we can look at a complete log and not miss anything. Debugging turned on for the Hue is indeed a good plan.
Not a problem, I’ll start a clean install on the rPi2.
[quote=“akbooer, post:28, topic:189406”]The thing that it making the logs so extensive is that you are testing this on a fully configured system. I see: VeraBridge linking to a remote Vera with Zwave activity, scenes running, the Extensions plugin, System monitor plugin? …
I don’t expect that this will change anything (although there is the remotest possibility that several plugins are, somehow, interfering) but it will make things a whole lot easier to understand. Then we can look at a complete log and not miss anything. Debugging turned on for the Hue is indeed a good plan.[/quote]
[4] Enabled debug mode (observed bridged link was set to 1). Reloaded engine.
[5] Turned on office lamp (device 5) using iPad.
[6] Waited 5 minutes for a poll.
[7] Set bridge link to ‘1’ by overwriting the ‘1’ that was already there.
If you’re running the same version of the Hue code as I am, then there is an error on line #925
This:
should be:
local bridgeLink = luup.variable_get(SID.HUE, "BridgeLink", lug_device) or ""
Since it appears to work on a real Vera, I can only suppose that there is an undocumented feature (I think) that missing out the device number in such a call defaults to the current running device.
[quote=“akbooer, post:33, topic:189406”]If you’re running the same version of the Hue code as I am, then there is an error on line #925
This:
should be:
This would stop the polling from ever happening…[/quote]
Hmm, appears we may have different files… My files has two entries matching at lines 907 and 949.
Edit: The file was an edit by a member to allow support for Cree and Lux bulbs - that would be the reason for the difference.
[quote=“CudaNet, post:35, topic:189406”]Hmm, appears we may have different files… My files has two entries matching at lines 907 and 949.
Edit: The file was an edit by a member to allow support for Cree and Lux bulbs - that would be the reason for the difference.[/quote]
Line #907 is correct - ‘device’ is defined in that function’s parameter list.
Line #949does need changing - as previously indicated.
You never cease to amaze me… Lamp was turned on via my iPad.
Edit: Had to update the log data to show the lamp was on…
2015-11-07 12:45:39.738 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[1] ON - No UI update needed!
2015-11-07 12:45:39.738 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[2] OFF - No UI update needed!
2015-11-07 12:45:39.739 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[3] OFF - No UI update needed!
2015-11-07 12:45:39.739 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[4] OFF - No UI update needed!
2015-11-07 12:45:39.739 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[5] OFF - No UI update needed!
2015-11-07 12:45:39.739 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[6] OFF - No UI update needed!
2015-11-07 12:45:39.739 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[7] OFF - No UI update needed!
2015-11-07 12:45:39.739 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[8] OFF - No UI update needed!
2015-11-07 12:45:39.739 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[9] OFF - No UI update needed!
2015-11-07 12:45:39.740 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[10] OFF - No UI update needed!
2015-11-07 12:45:39.740 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[11] OFF - No UI update needed!
2015-11-07 12:45:39.740 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[12] OFF - No UI update needed!
2015-11-07 12:45:39.740 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[13] OFF - No UI update needed!
2015-11-07 12:45:39.740 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[14] OFF - No UI update needed!
2015-11-07 12:45:39.740 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[15] OFF - No UI update needed!
2015-11-07 12:45:39.741 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[16] OFF - No UI update needed!
2015-11-07 12:45:39.741 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[17] OFF - No UI update needed!
2015-11-07 12:45:39.741 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[18] OFF - No UI update needed!
2015-11-07 12:45:39.741 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[19] OFF - No UI update needed!
2015-11-07 12:45:39.741 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[20] OFF - No UI update needed!
2015-11-07 12:45:39.741 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[21] OFF - No UI update needed!
2015-11-07 12:45:39.742 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[22] OFF - No UI update needed!
2015-11-07 12:45:39.742 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[23] OFF - No UI update needed!
2015-11-07 12:45:39.742 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[24] OFF - No UI update needed!
2015-11-07 12:45:39.742 luup_log:4: (Hue2 Plugin)::(pollHueDevice) : Lamp[25] OFF - No UI update needed!
[quote=“akbooer, post:37, topic:189406”][quote=“CudaNet, post:35, topic:189406”]Hmm, appears we may have different files… My files has two entries matching at lines 907 and 949.
Line #949does need changing - as previously indicated.[/quote]
