Hi akbooer,
It looks simpler (and less risky) if I can change the offset in VeraBridge. Looking at the current code this gets calculated again after each restart. Could it be made the initial offset gets calculated at first install and then taken from the off-set variable? This way you can also remove a VeraBridge without impacting the numbering of any remaining. I must admit I do not understand the role of the Primary Bridge (OFFSET == BLOCKSIZE).
