I have a window which I can controll with a Qubino window blind, and also several temperature sensors.
For the moment twice a day I open the window ( turn on a ventilator ) and half an hour later the window closes again.
I would like the window to be fully open twice a day , but not fully close it . I want the window to open/ close a little bit depending on temperature.
For example:
at 10:00 , the window opens full
Temperature is above 15 degrees celcius
at 10:30 , window closes to 30%
Temperature is below 15 degrees celcius
at 10:30 , window closes to 5%
Inputs:
-Temperature above 15 degrees
-Temperature below 15 degrees
-schedule: every day at 10:00
Ahh , I see , there is also a 10:30 Time schedule. I have it now as an "immediate"and than a delay of 30 minutes.
Second question , the pTemp > 15 and the other one , is that a logic input where I enter :"temperature goes above 15 degrees"and the other one “Temperature goes below 15 degrees”?
What I’ve done is use the “Logic Input” type “Device Properties”. This makes the variable the current temperature instead of a true/false, and as such you can re-use it anytime you want in a condition instead of having to make new triggers for every temperature.
I haven’t actually tried it, but I’m guessing at least one of these two would work:
s10_30 AND pTemp > 15
s10_30 AND pTemp > 7 AND pTemp <= 15
s10_30 AND pTemp > 2 AND pTemp <= 7
s10_30 AND pTemp <= 2
or
s10_30 AND 7 < pTemp <= 15
s10_30 AND 2 < pTemp <= 7
Just to clarify, since you didn’t know about the device properties type of logic input. s10_00 and s10_30 would be created as the “Schedules and Timers” type.
I am happy using the schedules and timers. Never used ( or even saw) the device properties option… probably no idea what it could do and mentally blocked it
Before I implement it, since you showed me 2 possibilties; Do you have a suggestion how I can test it , since I can not really influence the temperature.
I just implemented it , let’s see of it works how imagine it.
One more question though.
I have 2 time schedules , one at 10:30 and one at 20:30
will these conditions work:
(V_Ventilator_at_10_30 OR V_Ventilator_at_20_30) AND V_OAT >15
(V_Ventilator_at_10_30 OR V_Ventilator_at_20_30) AND V_OAT > 7 AND V_OAT <=15
(V_Ventilator_at_10_30 OR V_Ventilator_at_20_30) AND V_OAT > 2 AND V_OAT <= 7
(V_Ventilator_at_10_30 OR V_Ventilator_at_20_30) AND V_OAT <=2
The idea is , that when it’s 10:30 or 20:30 the action fires depending on the temperature. Did I do that correct?
That is the condition where it all starts;
There is a time schedule at 10:00 and a time schedule at 20:00
This condition was true at 10:00 , but did’t go true at 20:00.
Does anyone knows what is wrong in this condition:
V_Ventilator_at_10 OR V_Ventilator_at_20
The idea is that at 10:00 and at 20:00 the condition becomes true , I don’t understand why it works at 10 , but not the second part of the condition.
I don’t see how it could get confused when there’s only one operator (AND). If you look at V_Ventilator_at_20, what does it say in the last true/last false columns? Is it working correctly there?
It is not that condition which is not working ( The one with the temperature in it, the temperature one , to close the window partially is working just fine!). It is another condition which opens the window and starts a ventilator. Once at 10:00 and once at 20:00
This condition, nothing else there (no AND, just OR):
Today I tried again ( with other times a bit closer to eachother for testing;
Both schedules became true:
V_Ventilator_at_10 : that one became true at 10:00
V_Ventilator_at_20 : That one became true as well
But the condition is wierd:
The condition became true at 10:00 , but not at 20:00, something with the OR statement is wrong.
Yes, my reply should have said “…one operator (OR).”.
Do you mean that the entire " V_Ventilator_at_10 OR V_Ventilator_at_20" became true or that both V_Ventilator_at_10 and V_Ventilator_at_20 became true at 10:00?
If both of them became true at 10:00, double check that V_Ventilator_at_20 is set correctly and not accidentally a copy of V_Ventilator_at_10.
This condition: V_Ventilator_at_10 OR V_Ventilator_at_20
Became true only at 10:00 , that condition should also become true at 20:00 , but it doesn’t.
When I look ate the schedules tab, I noticed that at 10:00 the V_Ventilator_at_10 became true and at 20:00 the V_Ventilator_at_20 became true.
What I can see from that , is the schedules are correct , but there must be something wrong in the condition , why doesn’t the condition become true at 20:00 ( when the 20:00 schedule does become true).
That is super weird… I suppose, if you haven’t already, you could try remaking the condition in case something is messed up that you can’t see. I guess it can’t hurt to play around with brackets either.
