I have a few triggers that set of an alarm when armed. It will be armed at a certain time and if I activate a scene like “goto bed”.
The problem is that if one of the door sensors is still triggered (open), it will imediately trigger the alarm.
What I would like to establish is that the alarm checks if the door sensor is triggered at the moment that it will be executed and then give a message that you first have to shut the doors to execute the scene.
Is this possible in pleg and how should I do that.
I installed PLEG and the pl core, but when I open the PLEG it says that I have to install the core first. What am I doing wrong here?
But how about the triggers. Can i get a an alarm when the door sensors are tripped when a scene starts to arm the sensors. I can’t seem to find the scenes in the program logic plugins.
There is no way to trigger when a Scene is started.
You can trigger based on the side effects of the Scene.
Instead you can have a Virtual Switch that controls the arming of your alarm.
Turn it on.
PLEG can detect that … verify that all security sensors are in the proper state.
If so … then it can actually arm the alarm system … if not it can notify you with an alert (Push or Vera Alert, or Sonos Announcement)
When PLEG detects that the alarm is disarmed … it can automatically turn off the Virtual Switch.
