Hi, I am using UI5 for a while now and expanding my system all the time. I recently installed some door sensors and an alarm system. I trigger the alarm to be armed at a certain time and when I press certain scenes.
What I like to do now is the following: prior to the time that the alarm kicks in or at the time I arm the alarm sensors. and they are triggered at that moment (i.e. I forgot to close a door), I would like to get notified on my phone through SMS or email. The scene must be delayed until all is closed.
I do not know anything about Luup, but if that should do the trick, I like to learn to work with it. If anybody has an idea, please share.
Rather than heaving to learn to write Luup code, I recommend that you investigate the Program Logic Event Generator (PLEG) plugin. This will allow you to implement just-about any scenario you want without the need for code.
PLEG has its own child board on the forum and a search will reveal many examples of it being used for simple and complex logic.
I was just reading about and testing the PLEG. It doesn’t work yet, but I have to study more on it I guess. One thing that it keeps asking is that I have to install the logic core (which I have installed), so that is a thing I have to look into.
This all works for the installing of the PLEG etc. But now my PLEG keeps looking for PLEG_inputs for about a day now. None of the solutions on the forum worked. still no inputs.
I also installed the app “dropbox camera uploader” and i nticed that it also hang on the first page. When I solved that by authorising it, suddenly the inputs at PLEG where available. maybe they use the same handler.
