On the UI simple page (http://wiki.micasaverde.com/index.php/UI_Simple#lu_sdata:_The_polling_loop), you can use lu_sdata to only get changes since your last request. Does the same feature exist with user_data? If not, is calling user_data every second a particularly intensive operation for the Vera Edge?
I can have a ‘long poll’ and only changes will be sent to me. I’ve tried this using the URL: http://:3480/data_request?id=status&LoadTime=DataVersion=&Timeout=60&Minimumdelay=2
However it simply returns the full status response, regardless of whether there have been any changes or not. Should it be doing this?
Ha yes! I actually cut and pasted your string for a start, and thought I had deleted the & when plugging in my actual load time. Well spotted. Always pleased to hear that Vera works the way that you think it’s supposed to work.
