Hi all,
I want to setup a PLEG condition that will only fire once per day (maximum) starting from the time at which a Zwave device is turned on until a maximum of 4 hours after that device turns on and a power condition is met.
In other words, once the a zwave device is turned on, if the power of that device exceeds XX watts and the time is between 0 and 4 hours after it was turned on and a maximum of once per day… I want a condition to be true.
I can’t figure out how that is done. I can get the PLEG to work without the time constraints, however. My question is how do i make it work only once per day maximum and only between 0 and 4 hours after a Zwave device turns on.
