One way to send email through a server requiring Authentication through Lua
  1. Lua dont support Mail servers requiring authentication (acts weird and does not support SSL)
  2. For this you would need a local webserver to actually send the email - then use the following code in your scene
  3. Mios will stop Notifying you, after you reach your Quota limit for the day
  4. If there are other ways to accomplish this, please share… :slight_smile:
--Lua code to send email by requesting HTTP GET
function url_encode(str)
  if (str) then
    str = string.gsub (str, "\n", "\r\n")
    str = string.gsub (str, "([^%w ])",
        function (c) return string.format ("%%%02X", string.byte(c)) end)
    str = string.gsub (str, " ", "+")
  return str
function send_email(subject, body)
	local http =  require("socket.http")
	local b, h, c, e = http.request{ url = "http://localwebserver/mail.aspx?key=somekey&subject=" .. url_encode(subject) .. "&body=" ..url_encode(body) }
function send_motion_trip()
	send_email("Jay Home - Motion Detecter Notification", "Garage Motion Detecter was Tripped on " .. os.date("%A %c"))
send_motion_trip()
Your local webserver depending on what you’re running could use something like this…(This is in .NET, but could be in PERL or anything that supports mail servers requiring authentication)
            If  Request.QueryString("key")<> "yoursecretkey" Then Exit Sub
            Dim SmtpServer As New SmtpClient()
            SmtpServer.Credentials = New Net.NetworkCredential("username@dmomain.com", "password")
            SmtpServer.Host = "server.needing.authentication.com"
            Dim mail As New MailMessage()
            mail.From = New MailAddress("user@domain.com")
            mail.To.Add("user@domain.com")
            mail.Subject =  Request.QueryString("subject")
            mail.Body = Request.QueryString("body")
            SmtpServer.Send(mail)
