One Reactor Sensor for scene controller
I want to use a Fibaro dimmer only as scene controller. I will connect it to a double wall switch. Then I have 2 buttons and for each button 3 actions I want to use: single, double and triple click. Question can I use 1 Reactor Sensor to Define all the button actions. Like if button 1 is pressed once → LastSceneID = 16 → do action A If button 1 is pressed double → LastScene ID = 14 → do action B.
So I want to link specific Activities to specific Condition groups. Is this possible (I was not able to find it on the forum)
I think so. I have one Reactor for each of my ZRC-90s with different activities for each press. Just define one group of conditions for each press.
C
Ok but how can I add a separate group? I only see buttons to add condition to an existing group or make a subgroup at an existing group. Sorry for my ignorance…
Edit: I found the solution: have to define more subgroup. For every subgroup I can define specific activities. So this is solved
That’s it :slight_smile:
C
