For the last 2 FW revs or so, my on/off switches (all Linear) show up as “Unknown” type or category. I’m not sure when this started, but it happened about the time my Linear garage door actually showed up correctly. See attached. Any ideas?
I have the same issue. Any ideas?
I’ve the same issue.
I went to the switch’s “Advance-Params”, and changed the “subcategory_num” to “0”. Then the problem went away.
all of my light switches and dimmers were set to sub category 3. I didn’t do that so it changed along the way somewhere… changing to 0 fixed as you said. Thanks.
