Ohhhhh, "cannot benchtest". I think I get it now. What should I do?
When I was first fumbling around with all these new toys, I didn’t comprehend the part in the manuals that warn you need to set them up where they will be used. The instructions warned not to “bench test” the Devices first. Well, in a couple of cases, I either did what I was told I shouldn’t do, or I’ve moved the the devices to a new location.
I’m guessing I’m supposed to set them up at the location of intended use so that all the devices talk to each other properly based on their proximity. Is that correct?
That being the case, with devices that have been moved, what should I do about it?
Just run a network heal, this will allow Vera to establish new mesh network routes based on real world signal strengths it is measuring.
Thank you! I will figure out how to do that :stuck_out_tongue:
Log into your device. On the menus go to Setup → Z-Wave Settings → Repair → GO
Also, clicking on the “?” in the Vera web interface takes you to the MIOS online documentation. Typing into the Search box “network heal” reveals a wealth of information, including this link.
http://docs5.mios.com/doc.php?language=1&manual=1&platform=3Lite&page=Device%20stopped%20communicating
Hope this helps,
-TC
It helps a lot. Thank you! I have found those help docs overwhelming as a n00b, but maybe soon I’ll feel comfortable enough to read them again and absorb more knowledge this time.
