October Beta Update - Brave souls wanted. ;)
Wanted: Brave souls to update to the latest beta firmware and report back to the forum. After last time’s fun and games with my ZCOMBO’s I’m gonna hold off a few days. :wink: (found on the Vera website)
NOTE: As stated, it is a BETA and not a general public release.
Vera Beta Software Update ▾ UI7 ▾ Version 7.0.12 (1.7.707/1.7.1509) ▾ October 23, 2015
Last Updated: Oct 23, 2015 01:34PM PDT
The Vera Beta Software Update Program allows users try out pre-release software. The feedback you provide on features, quality, and usability helps us identify issues, fix them, and improve the overall Vera user experience.
Please note that since the public beta software has not yet been commercially released, it may contain bugs, errors, or technical inaccuracies. It may not function as well as General Availability Software Releases.
Please submit feedback via the following email address beta@getvera.com.
Be sure to back up your Vera Smart Home Controller before installing beta software. Install only on non-production controllers that are not mission critical. We strongly recommend installing on a secondary controller, and not on your primary controller.
While installing the beta software does not void your hardware warranty, we do not offer any Customer Care on the Beta Releases, beyond bug submission. Customer Care is only provided for controllers running General Availability Software Releases.
Again, we will not offer Customer Care via normal support channels (support@getvera.com, http://support.getvera.com, and +1 (866) 966-2272) for controllers running beta software.
Vera3, VeraLite, & VeraLite G: [url=http://download.mios.com/rt3662_betafirmware/rt3662_Luup_ui7-1.7.707-en-mios.squashfs]http://download.mios.com/rt3662_betafirmware/rt3662_Luup_ui7-1.7.707-en-mios.squashfs[/url]
VeraEdge: [url=http://builder1204.mios.com/mt7620a_betafirmware/mt7620a_Luup_ui7-1.7.1509-en-mios.squashfs]http://builder1204.mios.com/mt7620a_betafirmware/mt7620a_Luup_ui7-1.7.1509-en-mios.squashfs[/url]
If it fixes my smoke alarms I will do it. I am tired of seeing the red flashing icon on my Impurihome control systems.
Change Log?
Oops! C&P overflow error on my part. Please see below.
Issue Type Priority Summary Component/s
New Feature Major (Customer Request) Add support for Color Control CC to support Zipato RGBW light bulb LuupEngine
Improvement Major CLONE - UI7 - Users & Accounts Info / Account Info *** Special Characters Not Accepted *** Web UI
Epic Critical Fibaro Window Covering Roller Shutter-GEN3 Device Integration Management
Epic Major Yale Door Lock T1L(YRD120) Touchscreen Deadbolt Device Integration Device integration Management Process
Epic Major Netatmo plugin - Weather Station Device Integration Management
Epic Minor Netatmo Weather Station Device Integration Management
Epic Minor Danfoss Living Connect Radiator GEN3 Device Integration Device integration Management Process
Epic Minor Secure Radiator SSR303-GEN3 Device Integration Device integration Management Process
Epic Trivial Vision CO Sensor Z-Wave 6301 Wireless CO Detector-GEN3 Device Integration Device integration Management Process
Epic Trivial NuTone Garage Door Opener NGD00Z-GEN5 Device Integration Device integration Management Process
Epic Trivial Sercomm 8110/VistaCam 700 IP Camera Device Integration Device integration Management Process
Bug Blocker Cannot turn Zipato RGBW bulb on from Dashboard Web UI
Bug Blocker FirstAlert zCombo is tripped by every alarm type LuupEngine
Bug Blocker Devices are not displayed anymore Web UI
Bug Blocker (Customer Issue) Vera does not boot automatically in case of a power loss. LuupEngine
Bug Blocker (Customer issue) VERA UI7 Firmware capability to connect to a wireless router is not working Web UI
Bug Blocker Interface is blocked by spinner when trying to access alerts from Dashboard Web UI
Bug Blocker Unable to enable Secure unit Web UI
Bug Blocker Temperature color pickers are not working - Zipato Switch RGBW LED Bulb Gen5 Web UI
Bug Blocker Unable to enable USB logging on G150 LuupEngine
Bug Blocker Interface is blocked by spinner when trying to access notifications for a specific device Web UI
Bug Blocker PNP missing for Aeotec Switch RGB LED Bulb ZW098-Gen5 Web UI
Bug Blocker Tokens are not renewed after MMS is restarted LuupEngine
Bug Critical Email address not detected properly on User info page Web UI
Bug Critical Notifications are multiplied by itself (random) Web UI
Bug Critical “Autountrip” variable makes Vision D/W sensor return to untrip after 5 seconds LuupEngine
Bug Critical Spinning wheel doesn’t disappear in Control tab for sensors Web UI
Bug Major Inconsistency in dimmer bar for Zipato RGBW Web UI
Bug Major Superposition for TempLeakSensor when window is resized Web UI
Bug Major Secure SSR303 needs to display only Heat and Off controls Web UI
Bug Major There is no view for error on accessing Notifications Settings page Web UI
Bug Major Icon not changing when lights are turning On Web UI
Bug Major Status message displayed under control buttons for several devices Web UI
Bug Major “No actions could be found for the following devices” displayed when a heater is selected at Step 2: Device Actions (Scenes) Web UI
Bug Major “No actions could be found for the following devices” displayed when a thermostat is selected at Step 2: Device Actions (Scenes) Web UI
Bug Major Incorrect icon for GDO when device is closed Web UI
Bug Major Error message when trying to exclude Danfoss radiator Web UI
Bug Major Error message when trying to exclude ZXT-120 Web UI
Bug Major Cannot set temperature with decimals from web UI Web UI
Bug Major Camera snapshot too large on Manually add camera Step2 Web UI
Bug Major If Vision Glass Breaker is tripped once then variable “Tripped” reports “1” twice LuupEngine
Bug Major Unable to set the target temperature using decimals - Thermostats LuupEngine
Bug Major Linear D/W Sensor WADWAZ-1 always tripped LuupEngine
Bug Major Secure SSR303 device shouldn’t contain curent setpoint arrows Web UI
Bug Major Buttons Heat and OFF buttons should be hidden for Heater Secure SRT device Web UI
Bug Major Relay heater cannot be turned off from House modes Web UI
Bug Major Incorrect triggers and notifications for relay heater Web UI
Bug Major Negative values displayed for timer when changing house modes Web UI
Bug Major Token displayed in Add Device Wizard for Poly Control Doorlock Web UI
Bug Major Devices without wizard cannot be excluded from interface Web UI
Bug Major Remove variable “AutoUntrip” for Vision Glass Break Sensor LuupEngine
Bug Major Error message when trying to exclude Secure SRT321 heater Web UI
Bug Minor 2 spinning wheels displayed when changing house modes in 3G mode Web UI
Bug Minor “Vera IP changed” is displayed all the time when you make a change in Net & Wi-Fi Settings and unit has already a static IP Web UI
Bug Minor Inconsistency when hover over Time Restrictions in scene creation Web UI
Bug Minor Issue when you filter alerts by type and “Date/Time” is not “Today” Web UI
Bug Minor Incorrect text for GDO for opened/closed button Web UI
Bug Minor Unknown category for Garage door opener Web UI
Bug Minor Sort Other Users according to username or user type Web UI
Bug Minor “Energy goes below 0” shouldn’t be valid trigger in Scenes Web UI
Bug Trivial On Device - Controll page, toggling an on/off switch provides no feedback until a Z-Wave reply is returner Web UI
Bug Trivial Wait <5 seconds before changing from home to mode - no feedback on change mode
Nothing in here about fixing the phantom devices problem… I’m out!
Beta? As if any of the other releases raised to the level of production.
No fix for thermostat setpoints, that was promised :cry:
I am out
While I agree, I do appreciate them calling them Beta now and allowing some more real world testing before releasing it as a general release. I think it’s a move in the right direction.
[quote=“kornev, post:6, topic:189339”]No fix for thermostat setpoints, that was promised :cry:
I am out[/quote]
This is disappointing. I miss being able to set my thermostats to Auto and setting a cool AND heat point at the same time like I could way back on my Vera2.
Also don’t see anything about the multisensor 6 which has been unusable for me since I bought it :frowning:
No multi sensor 6. I am out also.
How can they miss this.
Every fibaro device i add, vera adds another 2. So for every 30 devices i have, vera is showing 60 devices!!!
Nothing on the promised fix to the Fibaro binary sensors. No thanks
Nothing about vision security S5101-5 that appears as a _Generic IO 1 on Vera UI
I’m out
I’ve probably waited too long for this release, so this morning I bit the bullet and installed .12 “beta”. Crazy, I know :slight_smile:
Well, everything seems fine so far, on my 50+ device setup, and I am happy to report that setting heat/cold setpoints via LUUP and/or advanced editor finally works as expected, which is extremely surprising since there was nothing about it in the change list.
Frankly after seeing that change list says nothing about sepoints I started to think about jumping ship since this issue was critical to me and it hasn’t been fixed for over a year, but I am a happy camper now ;D (kudos to MIOS guys for finally delivering what was promised a long time ago )
Ok installed it, 2 out of 4 of my FA Smoke Alarms are still showing as “Waiting for wakeup to configure device” I have removed and reinserted batteries in them to get them to wake up but they still wont fix, I guess im going to try to readd them.
+1 for phantom devices problem
Ok removed and added my FA Smoke/CO and they are working correctly again. No false alarms and my status is green again.
Are they showing a CO device now or any indication Vera will recognize a CO alert if sent by the unit?
Good thing I put a ZCOMBO in the garage as my new car has remote start as a factory option. Once I am sure Vera can recognize a CO alert, I’ll have to program a scene to open the garage door if CO detected. I doubt I’ll activate it by mistake as it requires a press for lock door and then a double press to start the engine, But just in case, I’m covered.
There is no option for CO when creating a scene so im guessing no, if you tell me what to look for I will let you know. I’m still new to the vera programming, only had one for 2 months.
I receive the following error message permanently on top of every screen: “GET_LANG(system_error,System error) : Device: 9. Fail to load implementation file D_GC100.xml”
I assume this is for the Global Cache 100, which I do not have.
Also, the Aeon Smart Switch 6 Gen5 still does not work; part number ZW096-A02.
Is this the best place report this?
Aeon Smart Energy Switch stopped reporting energy usage.
VeraEdge/UI7
As per GetVera in my OP:
