[quote author=Z-Waver link=topic=16226.msg124023#msg124023 date=1377474456]
[quote=“Caffreyboy, post:16, topic:176624”]I’m not sure what trend you are referring to, but if you are suggesting that we are deliberately ‘breaking best practices by using portforwarding’ then I must ask you to consider that this was done firstly from micasaverde’s own instructions, and secondly, by sheer unfamiliarity with this aspect of computing.
Speaking for myself, I would not have chosen this port on my own. It was suggested that ports be forwarded here:
http://wiki.micasaverde.com/index.php/Advanced_Network_Setup
just below the title “Vera behind another router”
I may have typoed 23 instead of 22, but nonetheless, I suggest you check micasaverde’s own documentation.
That being said, I will try this suggestion.[/quote]
The trend I was referring to was that the people who are portforwarding are reporting the issue whereas the people who have no issue at all are not portforwarding.
But from the instructions(user generated wiki content) that you linked to:
[b]PORT 23[/b] : telnet access, not recommended because it can't be secured, anyone can login remotely.
A typo, as mentioned, but the documents clearly state that port forwarding is required.
From the documents:
Forward ports to Vera
If you’re using Vera behind your router you’ll need to forward some ports to it to make it work:
PORT 80 : it’s used for the web page viewing, you can secure access by using username and password (go to SETUP->USERS: add an user and check “Require a username and password to access Vera from within my home network.” then press SAVE)
PORT 23 : telnet access, not recommended because it can’t be secured, anyone can login remotely
PORT 22 : ssh access, it’s enabled after you set a root password and then telnet access is disabled.
If you don’t know how to forward ports from your router have a look here:
