I don’t know about you, but I get pretty fed up with writing:
x = luup.variable_get (serviceID, variableName, deviceNo)
or
luup.variable_set (serviceID, variableName, value, deviceNo)
Maybe I’m just lazy, but it’s prone to mistakes and gets messy when spread throughout a program.
Of course, you can just write get/set functions for specific variables or devices, but that’s a bit messy too.
What I’ve found useful is to create objects (using a constructor named [tt]Variable[/tt] here) with a get/set method for any of the device variables I’ll be using (and declare them at the start of the chunk of code). For example:
a = Variable (serviceID, variableName, deviceNo)
So you can thereafter simply write, for example:
b = a.get()
a.set(value)
The constructor code I use is this:
function Variable (service, variable, device)
return {
get = function ( ) return luup.variable_get (service, variable, device) end;
set = function (x,y) return luup.variable_set (service, variable, y or x, device) end}
The reason for the slightly arcane use of two parameters for set and the “[tt]y or x[/tt]” construct is so that set (and get) will also work with the colon notation widely used for objects:
x = a:get()
a:set(42)
In fact, it’s not necessary here because the get/set methods don’t need to access the [tt]self[/tt] parameter since the object’s service, variable, and device parameters are kept as locals in the original closure of the [tt]Variable[/tt] constructor itself.
Don’t know if this helps anyone else, but it works for me and smartens up a lot of code.
