NX-590E
Chris, I’ve never heard of the NX-590E, so this’ll be interesting. I suggest that you enable logging as I showed alexk to do a few posts ago, and capture the Luup log over SSH while you do a Luup restart, and capture another log while you do a zone scan from the Zones tab, and post the results.
[quote=“alexk”]at some point you told me to enable logging and then use the following SSH command.
tail -f /var/log/cmh/LuaUPnP.log
what do i need to disable what we started? just the logging check box in the alarm device or does the tail command also start something?[/quote]
Alex, the tail command stopped as soon as you pressed Ctrl-C. No long-term effects. So just disable the logging checkbox and you’re good to go.
Let’s see how far we get here on the public forum first. Please describe your system, how it’s connected to the Vera, what the issue is, and capture logs if you can. Solving your problem may help other users too.
