Hi, I have a NX-8 alarm panel with the NX-584 and a RS-232 to USB adapter connected. I don’t see any indication of the NX-584 being there, other than its blinking leds. I have a Vera-2 that works fine except this problem with interfacing the NX-8 panel. I don’t know how or where I would set a baud rate to match each one. I am new at this stuff and don’t have a clue. I do know a lot about the NX-8 panel though, as I am in the Alarm business. My whole reason for using the NX-584 is so when the alarm panel is armed, it will send a Zwave signal to lock my Zwave locks. If anyone could help walk me through the steps, I would SOOO! much appreciate it.
You’ll help us by telling us at which point in the installation instructions (GE Caddx Networx NX-584 NX-8E Alarm Plugin) you get stuck. Presumably you have the programming instructions for the NX-584; they are supposed to come with the hardware, but can be found online.
