Hi-
I have a “GE 45604 Z-Wave Technology Outdoor Module” plugged into a particular outlet. Sometimes the breaker for that circuit flips and the fountain pump that’s attached to it stops working. (Pump is controlled by some timers I’ve setup in MCV).
Is there a way to get an alert when the breaker pops and the device stops getting power?
You could use a relay with 120 volt coil to make a switch closer ( re-purpose a door / window switch) to prove voltage from breaker. Create an event to react based on lack of voltage to the coil…
