Hi guys, is this possible ? I know it’s possible on Android with the VeraAlerts app.
Does pushover support this ? Or is there a similar solution for iOS ?
Thank you.
Thank you.
Use Pushbullet instead of Pushover.
Hi Richard, thank you for the reply.
Pushbullet is kinda broken on iOS devices, currently. It logs the image, which is ok. But push notifications do not work, that’s why I’d rather use Pushover as it’s blazing fast and reliable for push.
Is it possible to differentiate the notifications depending on the profile ? For example, I want to receive the PUSH notification through Pushover, but if I want to check the camera capture, just open Pushbulet inbox ? Asking this, because if I add {Picture(DeviceID)} in Message override, I have a bad looking string on the Pushover push message, because Pushover does not support this keyword.
Hope it makes sense.
BTW, for some reason http://rts-services.com/VeraTemplates does not load on my side.
Create another Vera User.
Attach a Pushbullet profile to it.
Associate the Pushbullet profile wth that new user.
For notifications that you want a picture … add the new user to the list of users to notify.
Hey SPAM did you try Richard suggestion? I am curious if it worked for you? If so I might try the same.
