Notification through iphone
Before, I decided to go the forum community for help to delete/remove the notification when my ‘armed’ motion sensor is tripped, I tried to resolve the issue but to no avail. I would really appreciate any help (it’s very annoying). this is what I sequentially followed:
(1) Clicked the wrench of the device and in the “notifications” tab, I unchecked the ‘notify’ box and SAVED (did not work)
(2) Then I click the remove button - SAVED (did not work either).
(3) Then I did a heal with stress test.
After step 3 above, I went to the garage where my motion sensor is located and armed it through my iphone; I started to walk around in the garage. After couple of seconds, i still received a text message. Any help/feedback will be greatly appreciated.
how are you receiving the notifications? SMS, email or something else?
SMS not email. thanks for your prompt reply.
If you are using the latest UI5, check your Dashboard / Overview. There’s a section for “alerts”, check it out and delete the ones you don’t want.
ok thanks for your response. i am still hesitant to upgrade to UI5-i have read many issues in another tread. thanks again.
