Not Receiving correct feed back remotely - Trane Tstat
I have a Veralite connected to a Trane ZWave tstat (the trane tstat was from Verizon home control). When I view/control the tstat from a PC, local or remotely it works fine. When I go to view/control the tstat from my iPhone via iVera app or Safari, I show incorrect readings. For instance, the fan is on auto, it shows on auto via the PC but on the iPhone it shows it is ON.
Has anyone had issues with this?? My VeraLite has the latest firmware. Could this be a issue because it was from the Verizon home control??? I have a Schlage lock from Verizon home control and it works fine.
Any help or ideas are greatly appreciated.
@jimbostro,
Welcome!
IIUC, you’re showing the correct state on Vera’s Dashboard in a browser on the PC, but not in Safari on the iPhone? Which other readings are not right?
Correct, all PC functions work correctly but via iPhone, Safari/iVera app they do not display correctly. For instance on the iPhone, fan shows ON but on the Tstat & PC it is on AUTO. If you heat HEAT up on iPhone the COOL goes up, hit COOL on iPhone HEAT goes up. It does at least communicate but the feed back is all messed up. Hope this helps.
I appreciate your response!!
