Northq / EM6600
Hi Guys,
I’m using the Eminent EM6600 (which is a Northq energy monitor) for energy monitoring.
It worked fine with my Vera 3 Lite.
After a week I discovered dat the pulse factor was wrong en I changed it on the Device Properties Tab, after that I received the error “failed at: setting user configuration” after the next sync.
I changed the value back to it’s original value but i’m still getting the same error. It seems that the em6600 is not accepting any configuration changes, except the ones I inital set with the tool from Eminent.
When i check the logs on the Vera the only thing I find is:
01 12/06/12 11:00:09.206 ZWJob_SendData::JobFailed job#25 :cfg get #4 p0 (0x10de250) N:4 P:70 S:5 Priority 70 <0x2b8d7680>
04 12/06/12 11:00:09.207 <0x2b8d7680>
06 12/06/12 11:00:09.208 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusText was: #4: Setting user configuration now: #4: Setting user configuration #hooks: 0 upnp: 0 v:0xf0a060/NONE duplicate:1 <0x2bcd7680>
06 12/06/12 11:00:09.209 Device_Variable::m_szValue_set device: 8 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: VariablesGet was: 1,6000,2,2,3,0,4,50,5,20,9,48289276,10,2,11,0,12,564, now: 1,5000,2,2,3,0,4,50,5,20,9,48289603,10,2,11,0,12,564, #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2bcd7680>
01 12/06/12 11:00:09.209 ZWaveNode::config_SetUserConfig node 4 failed 1 jobs 10 <0x2bcd7680>
Does anyone have experience with changing values on the NorthQ/EM6600?
Hope that someone can help me.
Hi guys,
Solved the problem. i had inserted the wrong value for the Pulse factor.
Pulse factor is "How many Pulses10 per kWh".
My meter is mechanical with a value of 600
10=6000.
While finetuning I tried insert a value of 6003, at that moment I got the error while setting the config.
I corrected it by setting the Pulse factor to 6010 and changing the Pulse Count (kWh * Pulse Factor = Pulse Count). I could have left the factor at 6000, but I leave it alone for the moment ;D
Now the values in my Vera are in Sync with my meter.
I’ve been using this with a mechanical (disc) meter for a few months but I keep having discrepancies between the NorthQ and Vera.
The main issue is that it is not consistent. Can be anything between 10 and 30% difference (NorthQ always reads more).
Any suggestions how to get this better?
Already reset a few times and had it re -calibrate (5x press).
After 2 days of running the values are out of sync again.
I also have the problem that the NorthQ reads more than the meter itself.
I have made a support tickit with Eminent hoping they can help me.
Did you ever get feedback on this request?
Nope not yet.
I have mailed them again today.
Any news on this item?
I have the EM6600 included in the Vera-3 network.
But no readings at all.
Setup is done like [url=http://forum.micasaverde.com/index.php/topic,12569.msg95260.html#msg95260]http://forum.micasaverde.com/index.php/topic,12569.msg95260.html#msg95260[/url]
Ideas?
Cu Wim
I have this as well, sort of. My meter seems to indicate 75 revolutions per KWh. So I tried 750 initially, but it was way off. So then I doubled it to 1500 (assuming that there must be a 2nd dark spot on the disc somewhere) and it was closer, but now it was reading less energy. I then tested 1140 and now 1275 (it actually does accept a non-zero last digit), but it’s still reading a bit high. I’ll try to tune it to more accurate values.
What I think is happening is that the dark spot on the disc is actually quite wide and it may take some time to pass the sensor especially when consumption is low. I guess that tuning the “IR listen period” and “IR pulse width” might help here, but documentation is so scarce that I haven’t touched those so far.
Has anyone found ANY documentation on this gadget at all? Link to a manual? All I have got is a collection of forum links.
