Perhaps an odd question but interested if any one else has a zwave switch on there pc?
I remote into my pc regularly and on occasions it freezes (or what ever like pc’s tend to do on occasions) in such a circumstance a physical reboot is required by pushing and holding the power button - however if your not there this cant be done!
so if I have the base unit plugged into a standard zwave on/off switch I could simply power off the pc, then power it on and turn it on via WOL.
However I only use switches for lamps etc - is the load of a PC too much? will this be dangerous? is anyone else doing this?
I’m not, but I wonder if the PC would be able to WOL after having the power cut. I seem to recall that a sleeping PC that loses power is off when the power resumes (i.e., not sleeping). Simple to check by unplugging it when it is ready for WOL. If it resumes and can wake, then the setup may work. If not, then the likelihood is that it would not be in a ready state after a crash and power loss/resume.
This was a subject that was covered a long time ago and yes, there are people doing this.
To just cut the power is not normally great for hard drives and sometimes other components; especially green drives can be a little sensitive to this type of action.
Some do this by using a UPS which the PC is monitoring and when power is disrupted, the PC will be sent a message to shutdown. However not suitable if the PC is unresponsive.
WOL depends on the post power sleep state S1-S5. Depending on you NIC, and your BIOS settings most PC will enable WOL or resume after power cut.
Thank you for the replies. I am happy that I can WOL after full power cycle so happy with that and agree that a power cut to resolve freeze is by no means the desired solution but would be a fix maybe 4 times a year so on that basis I am happy to chance things a little.
my main concern was would the switch be okay under the load and it appears all would be fine so I shall go ahead and give it a go.
thanks as always to the community here for sharing your thoughts
Usually there is a BIOS setting to specify what the PC should do after an unsolicited power cycle. You could set it so that when the power comes back the PC boots up again - so the WOL step can be omitted.
To drive this further you could use the ping plugin to automate the power cycle - works of course only when the PC is no longer pingable when frozzen :o
