I had been using non-ASCII characters in room and device names and just to rule out those as the cause I have renamed everything into English :)[/quote]
you log file luaupnp.zip does not contain the information I need to undersatnd what happens.
you need to
set DEBUG mode on ALTUI device
reload luup
capture the whole log during the process and send it to me
Also could you go to misc/debug and get the variables of the ALTUI devices and share the result
you need to
reload luup
Also could you go to misc/debug and get the variables of the ALTUI devices and share the result[/quote]
Okay. But unfortunately my workflow page has come up empty. Everything completely gone. And yes, I had saved and reloaded many times without problems but now suddenly it’s blank.
Could it be that I’m running the beta? Should I roll back? How?
you need to
reload luup
Could it be that I’m running the beta? Should I roll back? How?[/quote]
Nothing to d9 with beta which is purely UI change.
I suspect your openluup setup is not correct
