noob - weather plugin based triggers yielding erratic scene operation
Hi everyone - I’ve been lurking for a couple months as I dove into home automation and bought the Vera and some switches, receptacles, etc. Fun and frustrating! I have worked in IT in the past and normally am not as helpless feeling as I am with some of the instabilities/glitches in the Vera UI & hardware and the necessity to learn this Luup code. There are a couples places mentioned sporadically as having lots of “Luup snippets,” but in reality there are very few and my youngish eyes can barely read some of the ones on the wiki due to choice of font and color, but those gripes for another day!
My immediate need is this - I created a scene that toggles an intake fan and an exhaust fan in my attic in uneven back and forth intervals so that my house maintains overall positive pressure and still moves air through the attics (two connected attics). So it triggers the fans on and off in a pattern for a little over an hour, it runs fine on its own. I then made a trigger to only run the scene when the Weather plugin says my outside temperature is 85deg F or above (eventually I will put in an actual temp sensor in my attic, but more or less this yields similar results).
My problem is this - it sort of seems to work the first time in the day the temp rises up above 85 (but sometimes I swear it is sitting there idle for hours until it finally clicks on and it will be way over 85 by then). And this is the weird part - subsequent triggers of the scene in that same day happen very irregularly. I envisioned it as being in operation anytime the temp was over 85 (actually if it ran 60 out of every 90 min, or something like that, that would be great if it was a continuous hot day). Sometimes it seems to only run once in a day, that first late morning 85deg F reading, sometimes it will run once, maybe twice more, at intervals that have little rhyme or reason.
Should I not even mess with this since I’ll eventually be doing an actual temp sensor, or should I try to fix it in place?
I look forward to participating in the community, I have built up a list of questions I will doll out over time here and hopefully my contributions will in time be valuable as well!
Thx
Hello,
There is a plugin called Combination Switch which is perfect for what you are trying to achieve.
[quote=“Brientim, post:2, topic:172279”]Hello,
There is a plugin called Combination Switch which is perfect for what you are trying to achieve. It enable you[/quote]
Good thinking. . .I’m actually already using that plugin to turn on some lights when it’s cloudy or rainy outside though. Can I install multiple instances of the same plugin?
Thx!
Like this. No one ever figures this out for themselves, don’t feel bad.
Yes. Goto APPS > My Apps > Combination Switch and when it opens Click on Create another.
Rename as required.
Thanks guys! I’m sure I have a dozen or so questions that, though seemingly complicated to me, are super easy for you to answer. Thank you for bearing with me as I learn!
Ok so I have my switch operating correctly, but now my problem is very slow/sometimes inaccurate weather data provided by google. Specifically, I want to have certain scenes run or not run when there is precipitation. As I sit looking out my window it has been raining for 45min or so, but I go to google, type in “weather” and it returns “mostly cloudy” (I’m signed in to Google and it knows where I am) yielding the same result as the Google Weather plug in.
Any ideas or alternate data providers to get this info from? It would be so cool if it worked . . .the outside temperature is close enough, but the precipitation based ones are just way off the mark. I’d get one of those “personal weather stations” in an instant if it could feed z-wave data.
Have a look at Rfxcom and their USB adapter. It integrated various weather station in with Vera.
Another way is to have sensor that is attached to an alarm zone.
