For dimming a light I want to use a Qees MyKey remote, which has 4 buttons. I can switch lights on and off using group-ID’ s 1 till 4 in the Qees device options.
How can I get to dim a light with one of the Qees buttons using my vera3 (UI5) controller?
Device #11
Automatically configure Use default behavior learn more
Wakeup interval (seconds):
Variables
explain these settings
ID 15
Poll this node at most once every seconds (0=never poll, blank=default).
Energy used (explain this)
Capabilities 19,22,0,1,1,1,B,|33,45,132:2,133,134,
Version 2,3,40,0,0
Manufacturer Qees
Model MyKey
Neighbors
Configured at 15-SEPT-2012 17:47
After that I configured at the tab ‘device options’ 4 groups, which correspond the four buttons on the remote.
At the button ‘set’ of each button I marked a device, like a lamp-switch.
When I press a button, the marked lamp-switch will switch on or off.
I also heave a switch with a dimmer. When this device is marked, the light will switch on/off when pressing the the corresponding button.
My question remains, how can I get this to work to dimm the lamp?
