Noob needing some help
after months of surfing I finally dove in and picked up a veralite and couple of linear dimmers and a couple of linear on/off switches. I was able to get them installed despite the lack of room in some boxes. my question in the dimmers are the ones that respond to the all on/off command on the vera control panel. How do i configure the on/off switches to respond to the all on/off commands?
Light switches should be automatically added to the all on/off switch. One of mine did not, and I am trying to figure out why. It is a relay switch. There must nee something in the device configuration that gets it included.
Hopefully someone knows the answer both of the jasco and linear dimmers respond to the all on/off command but linear on/off switches do not. The instructions say they will but may need to be configured by the controller with no additional information.
It includes configuration options for led and invertng which work fine but can’t figure this in out.
