No space left on device when accessing via FindVera.com
Hello,
Starting this morning, when I try to get a user_data request remotely (using findvera.com), I get the following message on my browser … anyone seeing this before? Interestingly enough, accessing the same data locally works like a charm …
Warning: session_start() [function.session-start]: open(/var/lib/php5/sess_f3b0d824476a72dd98b0f60be6c5be04, O_RDWR) failed: No space left on device (28) in /var/www/vhosts/controlmyhouse.net/ra1/include/misc_functions.php on line 7
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /var/www/vhosts/controlmyhouse.net/ra1/include/misc_functions.php:7) in /var/www/vhosts/controlmyhouse.net/ra1/include/misc_functions.php on line 7
Warning: Unknown: open(/var/lib/php5/sess_f3b0d824476a72dd98b0f60be6c5be04, O_RDWR) failed: No space left on device (28) in Unknown on line 0
Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php5) in Unknown on line 0
thanks!
-j.
The web server exceeded its quota. The issue is fixed now and everything should work just fine.
thanks a bunch CJ!!
