Hi there, have a computer running the Concierge service and can access the URL internally. I have windows firewall disabled and ports forwarded so I can confirm from the outside i can hit the Concierge server on the 2 TCP ports.
On my discovered devices i see my vera and IP Address shows LAN IP (no ports are forwarded to Vera as i use the relay)
I test connectivity and errors out. I have a paid license by the way. I hit Custom Settings and it shows real data from my vera (that seems to be ok)
Under the Google Home/Cast Devices my Google Home Mini never shows up, its on the same subnet and i’m not sure why its not working. Is there a way to force or set the IP?
Concierge Version: 2.023
Under my android phone when I setup the vera concierge it goes “linking your vera” then error: Couldn’t update the setting.
Can I please have some assistance? what am I missing?
