No internet access - wireless bridge
Hi
Yesterday i’ve installed the RFXCOM (usb) device on my vera. I made the intitial error in installing the App from “Apps” instead of following the installation procedure from Node Central Blog: Working With Vera On a Different Frequency (RFXCOM’s RFXrtx433) | Node Central
This caused my Vera 2 to go in a kind of rebooting loop. That meant i had to reset to factory default and restore an earlier backup. After following the instructions from node central blog, the RFXCOM plugin now works like a charm.
But since the restore, i have great problems in connecting through cp.mios.com. When i connect locally i get the error “no internet access”. I connect wirelessly to an airport extreme, and i have almost full coverage/signal.
When i run af network test, the system reports: Gateway: OK, DNSSERVER: OK, Google.com: FAIL, sta2.mios.com fail.
Have tried to enter the ISP’s DNS information directly, and for a moment i had internet access. But now it’s gone again. Regardsless of entering the DNS directly to my router or to my ISP’s DNS information.
Any ideas?
I’m running my vera as “Through a wi-fi accesspoint. Vera is a bridge” for several months now without any issues.
Cheers
I seem to be having this same problem. Were you able to resolve?
=== IP Configuration ===
eth0 Link encap:Ethernet HWaddr 00:0E:8F:82:51:C3
inet addr:192.168.81.1 Bcast:192.168.81.255 Mask:255.255.255.0
eth0:0 Link encap:Ethernet HWaddr 00:0E:8F:82:51:C3
inet addr:192.168.1.3 Bcast:192.168.1.255 Mask:255.255.255.0
inet addr:127.0.0.1 Mask:255.0.0.0
External IP:
=== Testing Gateway: 192.168.1.1 ===
GATEWAY:OK
=== Testing DnsServer: 192.168.1.1 ===
DNSSERVER1:OK
=== Testing External Servers ===
GOOGLE.COM:FAIL
sta1.mios.com:FAIL
cms1.mios.com:FAIL
ts2.mios.com TUNNEL CONN:FAIL
fwd4.mios.com:FAIL
fwd4.mios.com TUNNEL CONN:FAIL
SSH_TUNNELS:NONE
== DONE ==
I got exactly the same a week ago!! Pls help
EDIT: Solved, at least temporarily. Just changed back to “Automatically configure” after fiddling with manual ones for a couple of hours :-(. But now I am :slight_smile: again…
