VeraPlus latest UI7 V 1.7.2138 + AltUI V 1.63.1838
I created a new workflow 0-17 with some duplicate errors that I fixed using debug functionality on device 0-32 (AltUI).
When Luup restarted I get a window showing “No handler” on altUI page.
I stopped workflows and put debug mode on and found following error:
01 09/26/16 19:03:53.099 FileUtils::ReadURL 7/resp:0 user: pass: size 1 http://192.168.0.27/cgi-bin/get_status.cgi response: <0x76f2d520>
01 09/26/16 19:03:53.844 luup_log:32: ALTUI: error: Wkflow - initWorkflows fails to decode graph string for workflow 0-17 <0x77dbb320>
50 09/26/16 19:03:53.845 luup_log:32: ALTUI: debug: Wkflow - findStartState(17) <0x77dbb320>
02 09/26/16 19:03:53.845 luup_log:32: ALTUI: warning: Wkflow - findStartState(17) could not find start state <0x77dbb320>
01 09/26/16 19:03:53.845 LuaInterface::CallFunction_Job device 32 function SALTUI_altui1_EnableWorkflows_job failed [string “-- // This program is free software: you ca…”]:735: attempt to index local ‘newstate’ (a nil value) <0x77dbb320>
01 09/26/16 19:03:53.845 Lua_Job::Run job#5 : dev:32 (0x29c9b28) P:50 S:0 failed <0x77dbb320>
I removed workflow 0-17 content in AltUI variables page but still get an issue referring to workflow 0-17:
50 09/26/16 20:21:52.063 luup_log:32: ALTUI: debug: getDataFor(0-17,Wflow_) <0x74f8f520>
01 09/26/16 20:21:52.064 LuaInterface::CallFunction_Timer-5 function startupDeferred failed [string “-- // This program is free software: you ca…”]:665: bad argument #2 to ‘format’ (string expected, got nil) <0x74f8f520>
I tryed multiple AltUI resets and VeraPlus reboots without any effect, what can I do next please?
