Hi, I did everything according what i found here on the site.
To get mine dutchSmartMeter installed.
First it worked, but i messed something, so i Reset everything, back to factory settings and so on.
Then did it all again, but now I don’t receive data. (see pic.)
I tried it several times but no result.
How to solve this?
Thanks for your reply,
I send a print screen from the Serial Port configuration.
In the lowest “Used by device” I don’t know if I have to select something.
The pull down shows what the options are.
I didn’t choose a option, so after “Used by device” is still standing “- Please select -”
Now with your help I start from scratch again, reset Vera and with your remark i mind i use the following steps:
1 Upload dutchSmartMeter files
2 Create device slimme meter (after filling the fields - see picture - i pressed button ‘?reate device’)
2a So i didn’t fill in anything to Parent device… that seems OK to me.
3 Serial Port configuration (Used by device: slimme meter)
The created devices are visible (with value) see next post.
i have the same settings. if it does not work now, i guess you have a problem with the serial cable, maybe.
did you try to power down vera and start up again?
With you’re help I got the values… (and after all, it seemed to be so logical :-[ … stupid me)
Is it also possible to show me the values in Euros (together with example Watts and KWH)
Maybe I have to use the advanced settings for that device?
Any Idea?
